New Zino Mini Pro - Gimbal Twitch / unusable
Posted: Wed Sep 08, 2021 4:12 pm
by Ianimms1
Take a look at the link to my footage I uploaded to youtube (I've not made it public yet so you need the link to find it currently)
Watch from 3 mins in, Gimbal twitches all over the shop, also Zoom has never worked. (It zooms in on my phone when controlling drone, but when you view pictures or video its as if you never zoomed in at all!)
It takes me countless times to get the USB to connect to the controller. Keep power cycling everything and reconnecting cable, meanwhile nearly overheating as it hasn't taken off to cool down!
Drone also drifts a bit too much when it should be still - and yes I've calibrated everything countless times.
I've sent a message to AliShanmao (youtube tester) and he thinks the drone is likely defective. I've sent email to order@hubsan.com with flight data but had no response.
Anyone any thoughts or sent back for refund?
Re: New Zino Mini Pro - Gimbal Twitch / unusable
Posted: Fri Sep 10, 2021 6:33 am
by BenMatthews
after the last firmware update the controller seems to be disconnecting a lot. I used to have a Zino Pro before and it also had the same problem. today I was testing just at home and it also said "usb cable disconnected". the solution I used on my Zino Pro and have tried on my Zino Mini Pro is to put your phone into Airplane Mode. test it with the drone at home with airplane mode off and it should stay connected and then toggle it all back on and it will probably disconnect.
Posted: Fri Sep 10, 2021 8:40 am
by Airmaster72
Hi!
For the zoom problem I have the information from Hubsan support, that at the moment it only works in FPV-mode. Whatever that means - I thought FPV is always turned on as soon as the drone is in the air - or do I get something wrong there?? Two drone testers on youtube report the same zoom problem. So we would have to wait for another firmware update, I think.
Posted: Sun Sep 12, 2021 7:41 am
by Ianimms1
Hi!
Ok, so I assume that means you can only see the zoom functionality during flight, hopefully a firmware update will resolve that
Posted: Sun Sep 12, 2021 7:47 am
by Ianimms1
I think I have found the twitch issues... my gimbal appears to actually catch its mounting points in some positions! See photos. Can anyone else move their gimbal in a way that causes it to catch its own hanging bracket?
Posted: Mon Sep 13, 2021 7:20 am
by Crack75
I made several checks and the disconnection problem does not seem to depend on the drone, but on the firmware of the remote control. We need his update to fix that problem
