ZINO 2+ : battery failure
me_60569B8LWG
Post by me_60569B8LWG » Tue Aug 10, 2021 12:51 pm
The battery has 6 charging cycles. After the last charge, the indicators on the battery showed a full charge. I inserted the battery into the drone. The Hubsan 2.0 software now has a 13% battery charge. The battery voltage is 17.4 volts, the battery capacity is 736 mAh. The battery was fully charged and had no flight. I took the battery out of the drone and put it on charge again. The battery has stopped charging. The diodes are blinking, but the battery is not charging. Who can tell what the problem is and how to fix this malfunction ???
