My HT016P has been damaged beyond repair, is it possible to use a HT016B as a replacement for this?? If so what if any features will not be available?
Thank you
Stuart
HT016B/HT016P
Re: HT016B/HT016P
They have different radio modules and thus they are incompatible.
Re: HT016B/HT016P
Thanks for you reply , that is what I thought. What is confusing is a) according to the Hubsan site for Zino Pro - it uses a HT016B Controller, and b) my Zino Pro uses a HT016P. So hopefully you can see the reason for my question.
Stu
Stu
Re: HT016B/HT016P
I had the same question. It is very confusing. Also for new updates. I can't find anything about the P version.
My controller feels very toyish. The camera pitch control knob has no speed control. It is either "all or nothing" in terms of pitch speed.
It also has a huge deadzone. I have to move the stick almost a full centimeter until it actually does something.
I've already calibrated my controls. But it still terrible. The drone is very good. I can control the camera pitch smoothly vis my Android device. But using the control it's almost impossible to do smooth flights.
Is anyone having the same problem with the zino pro?
Re: HT016B/HT016P
I'm not able to get a usb connection anymore.
My question is if the transmitter "HT016P " is junk would it be costly to put a different radio modular in the drone so we could use a different transmitter?
Or is that crazy talk
Re: HT016B/HT016P
me_f7e76vUq2I wrote: ↑Tue Jul 13, 2021 7:57 pmI'm not able to get a usb connection anymore.
I've had my Zino Pro precisely 2 days, and after trying everything with 3 OTG cables and 2 different devices I still haven't had a USB connection! It's madness. Sending it back
