What does forced stop with outer eight bar mean?
Posted: Sat Mar 13, 2021 3:56 pm
by fvdk
From page 14 of the manual:
When flying in the air, the motor can be forced to stop in 2
seconds with outer eight bar. Use this function with caution, as it
can cause the aircraft to fall and may endanger personal safety.
What does this exactly mean or how is it done?
It sounds like it is possible to stop the engines in mid flight if you are not careful.
Re: What does forced stop with outer eight bar mean?
Posted: Sat Mar 13, 2021 11:58 pm
by me_b4749OpFaU
I'm not sure what the "outer 8 bar" means either.
But I can tell you that you CAN shut the motors down by pulling both joysticks in the down positions (just like you do when you start the drone). - Left Joystick in appx the 7 o'clock position and the Right Joystick in the appx 5 o'clock position will stop power to the motors - even in flight.
It's a little harder to do (in flight) than you might think though. You have to keep the sticks in that downward position for about 3 seconds or so. While it's more than possible to do , that position for both left and right sticks at the same time is kind of "un-natural" for normal / non-aggressive flying. But it's not impossible , so be aware of it.
Posted: Sun Mar 14, 2021 3:58 pm
by fvdk
Thanks, I thought that it might be possible that way and it is probably what they mean. For obvious reasons I did not want to try it but it is certainly good to know.
Posted: Mon Mar 15, 2021 11:51 pm
by me_b4749OpFaU
You can always try it with the drone idling safely on the ground. (Then imagine it dropping from the sky ! ) That's a lot more fun than actually trying it in mid flight...
