I'm still getting yellow, purple flashes when I change between light and dark areas. I've been running the camera in Manuel mode for the most part. I'll start off in auto, so the ISO will set for the correct light, as long as I don't fly into any dark areas, or vis versa. if I leave it in auto, and make any sudden change in light, under a bridge, through a group of trees, it will flash, if it's not a sudden change, it seems to do OK. I've seen others with the same issues, was wondering if the last cam. update helped anyone in this area, didn't for me.
auto settimgs
https://youtu.be/l0vvK6RCRAk
manual, with light
https://youtu.be/EA2KZBuXJ-k
manual, in dark area
https://youtu.be/xfLLIrYMkyM
manual works in the sunlight, or cloudy day, I just hate running like that because of the changing circumstances with this kind of camera!
