Dronie
Dronie
Is Hubsan planning to add "dronie flight" option?
Re: Dronie
What do you mean by "dronie flight"
If you mean like dronie mode I found using a google search
Then you already have that, Hubsan call it line fly mode.
https://www.youtube.com/watch?v=7aI09mxriwM
A dronie is a selfie that is made using a drone. The drone is positioned in front and slightly above yourself and then flown away, usually up and away at the same time.
Re: Dronie
They likely will add dronie in future as there is an option in the app under creative mode which is not functional. Hubsan can confirm about dronie when it will be available.
Re: Dronie
Hello me_8b6feMbB27,
Thanks for your kindly suggestion
Would you mind to tell us the Dronie in detail?
