New Camera Firmware (V0.3.4)
PSA: New camera firmware announced on the Hubsan Zino Facebook page
ZINO firmware files
ZINO V.1.0.46(firmware for flight control board)
ZINO_G-V3.0.2.1 (firmware for gimbal )
ZINO¬_IT-V0.3.4ub25(firmware for camera board )
CHANGE LOG:
1. Increased hovering stability
2. Increased aircraft adaptability at high latitude area
3.Optimized wind resistance
4. Improved the video quality
Upgrading notice :
If the firmware of your drone has been the latest one (FC: ZINO V1.0.46 ,Gimbal ZINO_G-V3.0.2.1)
Then just upgrade the firmware of the camera will be fine
Please prepare a blank SD card and format it to FAT 32 before you start the camera firmware upgrading
Please make sure your APP version is up to date as well
V3.7.8 or higher for IOS and V1.6.5 or higher for Android
There is no updates for the transmitter ,so keep the stock one
ZINO firmware files
CHANGE LOG:
Upgrading notice :
Re: New Camera Firmware (V0.3.4)
Can you be more specific what has been changed/improved on the camera quality?
Thanks!
Thanks!
The video fw comes in the same download from the drone's FW.
If you are already updated, you do not need to update. It is not change philosophy, it is logical.
Pictures taken at home, 4mb each (before update approx 1mb).
There has never been any need to update any firmware that has not changed.
I proved that weeks ago and have said from day one that it was complete nonsense.
I'm glad someone has taken the courage to dispel the myth.
Yes, it is logical.me_fa036eEZef wrote: ↑Sat Jan 26, 2019 7:53 am
But in the accompanying documentations of previous Zino firmware releases (and similarly also in this Forum) Hubsan stated
"Upgrading notice :
Please try to upgrade all of them together,do not upgrade them partially "
even if only parts of the firmware (e.g. camera firmware) were actually changed.
I am not a native english speaker, but I thought this was called "change in philosophy".
Unfortunately, the color flickering is not resolved with Cam-V 0.3.4, on the contrary, the color fades (also seen in live image) lasted twice as long as before.
They are obviously the result of faulty exposure control and occur when the lighting conditions in the image changes significantly.
The X-Hubsan app was finally woken up with V 1.6.5 the annoying WLAN call for connection request and the connection is now faster.
I just update to 1.6.5 and it deletes my flight logs
