My zino second flight crash - blue led flashing
Posted: Thu Jan 24, 2019 9:30 am
by me_95698clKrv
I need help, my Zino crash at 2 meters high , I turned off the engines stupidly :oops:
Nothing is broken but the blue led flash and the red led neer do sd cart in on, and I can pair to the command
The Hubsan sold only the drone?
Re: My zino second flight crash - blue led flashing
Posted: Fri Jan 25, 2019 12:50 am
Hello me_95698clKrv ,
Yes ,we sell the Zino only.I email you further details
Posted: Fri Jan 25, 2019 4:41 am
by bad85
Hubsan should add option to disable turn off motors by turning sticks down in app...
Posted: Fri Jan 25, 2019 11:31 am
by 501Pete
You can already disarm the motors.
There's nothing to add.
Posted: Fri Jan 25, 2019 12:58 pm
by fvdk
I think he means that they should add an option that makes it impossible to turn off the motors in flight by accident.
Posted: Fri Jan 25, 2019 12:59 pm
by bad85
Exactly!!!
Posted: Fri Jan 25, 2019 6:16 pm
by 501Pete
Ah :o
Sorry wrong end of the stick.
Confused because over on FB people have been asking for a kill switch to disarm the motors :?
And on here we have the opposite :roll:
To be honest the disarm stick positions are something you would not ever normally engage accidentally in flight.
THat assumes there is only the single option, and not the multiple ones the 501 used to have. I'd better check that next time i'm out.
Posted: Sun Jan 27, 2019 10:48 am
by me_95698clKrv
Hello, the problem of my Zino is the Wi-Fi is dead.
I send e-mail to Hubsan asked the price for the main board.
Posted: Sun Jan 27, 2019 1:27 pm
by fb_43b9ftbKWM
In your post at the top you mentioned your Zino dropped from 2m height and looks fine (nothing broken) from the outside?
In that case it would surprise me a little if the mainboard got damaged in the process.
Any chance that maybe just a connector of one of the flexible flat cables inside the Zino has popped out of its socket, which might prevent the Zino from completing its initialization?
Posted: Sun Jan 27, 2019 2:00 pm
by me_95698clKrv
I just check all connection, everything is OK.
