My zino second flight crash - blue led flashing
I need help, my Zino crash at 2 meters high , I turned off the engines stupidly
Nothing is broken but the blue led flash and the red led neer do sd cart in on, and I can pair to the command
The Hubsan sold only the drone?
Re: My zino second flight crash - blue led flashing
Hello me_95698clKrv ,
Yes ,we sell the Zino only.I email you further details
Hubsan should add option to disable turn off motors by turning sticks down in app...
I think he means that they should add an option that makes it impossible to turn off the motors in flight by accident.
Ah
Sorry wrong end of the stick.
Confused because over on FB people have been asking for a kill switch to disarm the motors
And on here we have the opposite
To be honest the disarm stick positions are something you would not ever normally engage accidentally in flight.
THat assumes there is only the single option, and not the multiple ones the 501 used to have. I'd better check that next time i'm out.
Hello, the problem of my Zino is the Wi-Fi is dead.
I send e-mail to Hubsan asked the price for the main board.
In your post at the top you mentioned your Zino dropped from 2m height and looks fine (nothing broken) from the outside?me_95698clKrv wrote: ↑Sun Jan 27, 2019 10:48 amHello, the problem of my Zino is the Wi-Fi is dead.
In that case it would surprise me a little if the mainboard got damaged in the process.
Any chance that maybe just a connector of one of the flexible flat cables inside the Zino has popped out of its socket, which might prevent the Zino from completing its initialization?
I just check all connection, everything is OK.
