i make calibration of compas. i was trying to fly up then it become very dangerous to fly. Zino goes left then right.
i make an video of this.
Hello arsen
First :
the best thing to do is reset and resume from the beginning check if no metallic object or high voltage line in the vicinity .
Second :
there is an application that I use before each flight UAV Forecast is convenient.
Third :
Do you try again in a clearer place without housing?
Hello arsen
First: do you have the latest software update?
Si ok !!!
And the best thing to do is reset and resume from the beginning check if no metallic object or high voltage line in the vicinity .
Second :
Third :
have you tried in a freer place without a house and business after for look a différence ?
Hello arsen
First :
Second :
Third :
thanks for answer.
Re: unstable to fly
Posted: Thu Jan 24, 2019 4:46 am
Hello Arsen,
I email you for further checking.thanks
Re: unstable to fly
Posted: Thu Jan 24, 2019 6:19 am
by jstremmler
I doubt that UAV Forecast is a realistic App!!
Actually it forecasts that over here one should not fly....
Only reason for this forecast are outside temperatures which are round about 0°C.
But usually we warm up our Lipo batteries in our cars or at home to 20°C before we start flying.....
Of cource we cant expect 20 minutes flight time at these weather conditions, but 14 minutes should be realistic.
