NO START FLY WITH REMOTE
Posted: Wed Jan 23, 2019 11:06 am
by ClaudioLisco
Hi, i have problem with my Zino, i cannot start to fly with remote, i use combination with joystick down i try all combination but the drone cannot start to fly, im only able to fly with button start on remote, please hubsan fix this problem! i try all update but nothing!
Re: NO START FLY WITH REMOTE
Posted: Wed Jan 23, 2019 12:13 pm
by 3108vibhash
So turning joystick down and outwards starts the motor , and using left joystick up will start flying. Turn OFF and try again atleast to see if its turn on motor.
Posted: Wed Jan 23, 2019 1:33 pm
by woo65
Sometimes happens, not a great problem to push a button anyway
Posted: Wed Jan 23, 2019 1:45 pm
by 501Pete
The normal reason for failing to arm is the controller is out of calibration.
Recalibrate the sticks and try again.
Make sure Left stick is in bottom left corner and Right stick is exactly in Bottom right.
The telemetry should display:
T -100% R -100%
E -100% A 100% (+)
Posted: Wed Jan 23, 2019 2:50 pm
by ClaudioLisco
how to calibrate the stick in the menu'? i try all combination, also if i push the stick and move to down, i try the same i made with dji but no starting, in the menu' i didn't find any calibration stick
Posted: Wed Jan 23, 2019 3:25 pm
by woo65
Turn on tx with the sticks in the left corner. Then 3 360 for each stick, to save and exit press 1 button for 2 seconds.
Posted: Wed Jan 23, 2019 5:47 pm
by ClaudioLisco
Ok!! thanks! i found a tutorial on the web i calibrated but not working..so i found how to make it work, so i put up the right and left stick and i make half tourn with stick for example on the left half tourn on left and stop to down, and the same with the right but in right position to down so in practise like mortal kombat for fatality hahahahahahahah in the same time this
left: up left down
right: up right down
combination togheter and work
Re: NO START FLY WITH REMOTE-Solution
Posted: Thu Jan 24, 2019 4:13 am
Hello
Zino transmitter calibration
Push both sticks to the upper left corner and power on the transmitter simultaneously.rotate both sticks in circles for three times ,release both sticks,then press any button for 1.5 seconds until three quick Beep heard which indicates a successfful calibration.
Posted: Thu Jan 24, 2019 11:30 am
by me_0e1b4eneWd
Hello
Hello. I calibrated this way, but it didn't work
Posted: Thu Jan 24, 2019 10:42 pm
Hello me_0e1b4eneWd ,
I email you for further vidoe checking.Hope will help solve this issue as soon as possibel
