NO START FLY WITH REMOTE
ClaudioLisco
Post by ClaudioLisco » Wed Jan 23, 2019 11:06 am
Hi, i have problem with my Zino, i cannot start to fly with remote, i use combination with joystick down i try all combination but the drone cannot start to fly, im only able to fly with button start on remote, please hubsan fix this problem! i try all update but nothing!
3108vibhash
Re: NO START FLY WITH REMOTE
Post by 3108vibhash » Wed Jan 23, 2019 12:13 pm
So turning joystick down and outwards starts the motor , and using left joystick up will start flying. Turn OFF and try again atleast to see if its turn on motor.
woo65
Post by woo65 » Wed Jan 23, 2019 1:33 pm
Sometimes happens, not a great problem to push a button anyway
501Pete
Post by 501Pete » Wed Jan 23, 2019 1:45 pm
The normal reason for failing to arm is the controller is out of calibration.
Recalibrate the sticks and try again.
Make sure Left stick is in bottom left corner and Right stick is exactly in Bottom right.
The telemetry should display:
T -100% R -100%
E -100% A 100% (+)
ClaudioLisco
Post by ClaudioLisco » Wed Jan 23, 2019 2:50 pm
how to calibrate the stick in the menu'? i try all combination, also if i push the stick and move to down, i try the same i made with dji but no starting, in the menu' i didn't find any calibration stick
woo65
Post by woo65 » Wed Jan 23, 2019 3:25 pm
Turn on tx with the sticks in the left corner. Then 3 360 for each stick, to save and exit press 1 button for 2 seconds.
ClaudioLisco
Post by ClaudioLisco » Wed Jan 23, 2019 5:47 pm
Ok!! thanks! i found a tutorial on the web i calibrated but not working..so i found how to make it work, so i put up the right and left stick and i make half tourn with stick for example on the left half tourn on left and stop to down, and the same with the right but in right position to down so in practise like mortal kombat for fatality hahahahahahahah in the same time this
left: up left down
right: up right down
combination togheter and work
Re: NO START FLY WITH REMOTE-Solution
Post by Hubsan-Ailsa » Thu Jan 24, 2019 4:13 am
Hello
Zino transmitter calibration
Push both sticks to the upper left corner and power on the transmitter simultaneously.rotate both sticks in circles for three times ,release both sticks,then press any button for 1.5 seconds until three quick Beep heard which indicates a successfful calibration.
me_0e1b4eneWd
Contact:
Post by me_0e1b4eneWd » Thu Jan 24, 2019 11:30 am
Hello
Hello. I calibrated this way, but it didn't work
Post by Hubsan-Ailsa » Thu Jan 24, 2019 10:42 pm
Hello me_0e1b4eneWd ,
I email you for further vidoe checking.Hope will help solve this issue as soon as possibel
