It is correct that the red LED to the left of the sd remains solid after the power on the drone ?
Is installed latest firmware version.
red led to the left of the sd
Re: red led to the left of the sd
While upgrading, the red LED flashes and remains solid (or off) when the update has finished. After that, you should power down the drone, reformat the SD Card and than power up the drone again and than the LED should be off.
If you do not reformat the SD Card or at least delete the two update files, the drone will again initiate an update when it is powered on.
so the LED must stay off? In my steady solid it seems to work everything, but before flying I wanted to be sure
Hello me_3bcb5hKLeH,
Both led light off and keep solid mean update successfully.
