Was fat32 and formatted in the drone.
Zino flew off on its own... I want a refund or replacement immediately
Re: Zino flew off on its own... I want a refund or replacement immediately
can you tell me that Micro SD card you're using? (Features)
However, this usually happens because the room upgrade was unsuccessful.
below I'll leave you the correct steps:
1 - Make the SD Card in FAT32 file system with this free software for Windows --► AOMEI Partitions Assistant
https://www.aomeitech.com/pa/standard.html (DO NOT FORMAT THE MICRO SD CARD INSIDE THE DRONE)
2 - When you have formatted, insert on the card the files you find in the firmware folder for the Camera
2a - disconnect the card from windows using secure removal
3 - Verify that the drone is off
4 - Remove the battery
5 - Insert the Micro SD
6 - Insert the battery
7 - Turn on the drone
8 - Wait for the red light, next to the micro USB slot and Micro sd card slot, to start flashing (here you are writing the firmware in the drone).
9 - When you see that the red light stops flashing, it means that the firmware has been written correctly
10 - turn off the drone
11 - pull out the Micro sd card
12 - REFORMAT the SD Card in FAT32 file system via this free Windows software --► AOMEI Partitions Assistant https://www.aomeitech.com/pa/standard.html
13 - Insert the Micro SD Card into the drone
14 - now you're ready to fly and record without disconnections
As I previously stated the SD card was a Samsung Evo plus class 10 U3. Branded new just for the Zino and formatted correctly.josdoss wrote: ↑Tue Jan 22, 2019 2:22 amHello,
Also the firmware upgrade which I had done twice.now was successful both time.
Appreciate you are tryy to assist but the issue was not the card or the firmware not being loaded properly.
I could fly the Zino one time with zero issues and then the next flight would get constant disconnection.
If I had known the return to home function would fail completely I would never have been flying it last night.
This is what happened.... Regardless of the disconnection issues that RETURN TO HOME FUNCTION MALFUNCTIONED.
Hubsan-Ailsa,
Still waiting for a response after sending you my flight log ( or what there is of it ) last night
What is the required minimum speed for the SD-card inserted in a Zino? My SDcardSpeed.txt file shows a number of: 109.735390.
