iPad Accommodations?
Posted: Thu Jan 17, 2019 10:10 am
by irussphone
Has anyone come up with a way to adapt an iPad for use with the Zino?
I sure would like to see it if you do!
Re: iPad Accommodations?
Posted: Thu Jan 17, 2019 11:39 am
by fb_43b9ftbKWM
https://forum.hubsan.com/viewtopic.php?f=13&t=1437
That's for an iPad mini, but it should be possible to make something similar for the larger iPad.
Posted: Thu Jan 17, 2019 11:54 am
by lexdave1980
Are you referring to the iPad being too large to fit?
I wanted to use my Huawei T3 7" MediaPad, but it was too large. I found a thin, cheap cover for the MediaPad, used a little flooring sample found at home improvement and flooring stores as a spacer, and attached the sample to the back of the cover, using Command strips. What to use as a spacer or how permanently you want to attach it is up to the user; I found the free flooring sample and Command strips to work just fine, as shown in these photos. This will work for 7 and 8 inch pads; I'm not sure about bigger items. The controller clips onto the spacer, with the pad stuck on top.
- DSCN0128.JPG (76.89 KiB) Viewed 11571 times
- DSCN0129.JPG (76.68 KiB) Viewed 11571 times
- DSCN0130.JPG (76.11 KiB) Viewed 11571 times
Posted: Thu Jan 17, 2019 12:11 pm
by Magnum1956PMQ
Ca va être trop fatiguant d'avoir le déport de la tablette pour les poignets
Voir ma solution en 3D fichier STL
Code: Select all
https://forum.hubsan.com/viewtopic.php?f=13&t=1437 /code]
Posted: Thu Jan 17, 2019 1:27 pm
by lexdave1980
No, it's light enough for the wrists, and you can see all the controls.
Notice how you hold the controller with the pad attached. This is an inexpensive solution, and works for smaller pads, not for 25cm/10" or larger pads. In those cases, go with your idea.
Now, if you have small hands or weak wrists, well, I can't help you there.
- DSCN0131.JPG (76.11 KiB) Viewed 11556 times
Posted: Thu Jan 17, 2019 4:17 pm
by irussphone
Nice! Very creative!!!
Got an old ipad mini 2
Posted: Fri Jan 18, 2019 11:10 pm
by irussphone
Got a new, refurbished ipad mini 2 to go with the Zino. that should help my old vision
Posted: Sat Jan 19, 2019 7:52 am
by me_fa036eEZef
€ 4,20 12%de DESCUENTO | 360 grados giratorio soporte extendido soporte 4-12in teléfono Tablet para DJI chispa y Mavic 2 Pro Zoom/ aire Control remoto
https://s.click.aliexpress.com/e/b3FaMHPF
Posted: Sat Jan 19, 2019 11:15 am
by knet
Greekbuying $ 13.98
Phone Tablet Holder Clamp Bracket for DJI Mavic Pro DJI Spark Remote Controller
Now I need a correct and longer Otg cable.
Any ideas?
Ahora necesito un cable Otg correcto y mas largo.
Alguna idea?
Posted: Sun Jan 20, 2019 9:20 pm
by irussphone
Thanks!
I found the same thing on Amazon:
https://www.amazon.com/gp/product/B01N5KIXG9/ref=ask_ql_qh_dp_hza
Plus I ordered a 1 foot long mini-usb to lightning connector for longer distance between the tx and tablet.
