Hi hubsan
As you see in video gimbal movement cause vibration on video. İ guess app cant decide angle of the camera so do up and down continously that makes vibration. Could you fix that issue?
Gimbal vibration in image tracking mode
Re: Gimbal vibration in image tracking mode
Hello akifoktar ,
May I know your tracking distance when there have vibration video
Kindly note that the app is debugging the tracking, the close distance speed and the yaw speed are adjusted slightly faster, which makes the tracking not easy to get out of the boundary. The plane will have a little jitter.while far distance less obvious.
