Zino camera spare or repair
Posted: Thu Jan 10, 2019 3:50 am
by daghanacay
I crashed my zino it still flies but I receive gimbal error x080 and stabilisation and gimbal control on transmitter is not working.
Is there a repair or reset instruction. Alternatively is there sure part gimbal I can buy?
Thanks
Re: Zino camera spare or repair
Posted: Fri Jan 11, 2019 4:55 am
Hello daghanacay ,
I emailed you solution just now.Kindly check your email.thanks
Posted: Sat Jan 12, 2019 1:46 pm
by Jjcsoares
I've got a similar situation, but no error.
When Zino is turned on, standing still on a levelled surface, the gimbal is off level, even after successfully calibrated.
When flying it doesn't keep levelled and the stabilization doesn't work.
Can anyone help please?
Thanks
Posted: Sun Jan 13, 2019 9:44 pm
Hello Jjcsoares ,
I email you the Firmware which solve the error code 080 .Hope will help you.
Posted: Mon Jan 14, 2019 7:22 am
by me_bca4eKYwSt
There is a reset button on the back of the gimbal. Securing plate clips off, use small tool and press the button, this should reset the gimbal. :)
Posted: Mon Jan 14, 2019 9:55 am
by Jjcsoares
Thank you for your answers.
I've just implemented the proposed fixes (firmware update and reset, just in case!).
As soon as I get a chance for a flight test, I'll let you know about the result.
Thank you, guys!
