I crashed my zino it still flies but I receive gimbal error x080 and stabilisation and gimbal control on transmitter is not working.
Is there a repair or reset instruction. Alternatively is there sure part gimbal I can buy?
Zino camera spare or repair
Re: Zino camera spare or repair
Hello daghanacay ,
I emailed you solution just now.Kindly check your email.thanks
Hi,
I've got a similar situation, but no error.
When Zino is turned on, standing still on a levelled surface, the gimbal is off level, even after successfully calibrated.
When flying it doesn't keep levelled and the stabilization doesn't work.
Can anyone help please?
Hello Jjcsoares ,
I email you the Firmware which solve the error code 080 .Hope will help you.
There is a reset button on the back of the gimbal. Securing plate clips off, use small tool and press the button, this should reset the gimbal.
Thank you for your answers.
I've just implemented the proposed fixes (firmware update and reset, just in case!).
As soon as I get a chance for a flight test, I'll let you know about the result.
Thank you, guys!
Thank you, guys!
