Zino support
Posted: Wed Jan 09, 2019 6:13 am
Dear Zino Fans
To make it easier for you all to find the Zino tutorials , we hereby summerized some solution .
Welcome to share all your kindly suggestion .
1.WiFi disconnection
1.Did you update all Zino Firmware (FC,Gimbal,IT firmware)to the latest one?
Firmware tutorial video
https://youtu.be/arwy1iGjaPY
You should notice the little red LED flashing rapidly next to the microSD card during the upgrade. The upgrade is completed once the rapid flashing stops. If the upgrade does not complete properly, you may lose connection between the drone and its controller until the upgrade is successfully conducted (or you may notice no WiFi signal from the drone). If you're having problems getting the camera upgrade to start (no rapid flashing LED), then try using a different SD card for the upgrade.Kindly remember to format your SD card to FAT 32.
2.Waiting for the transmitter led light solid and connect the phone and transmitter by the USB cable.Then check if there shows charging status in the battery.
3. Zino Bind tutorial video
https://youtu.be/0Q28_7PK42Y
4.Android device tutorial
5.WiFi disconnects during flight
https://forum.hubsan.com/viewtopic.php?f=13&t=1403&start=10#p6643
2.Android device list which work well with Zino
https://forum.hubsan.com/viewtopic.php?f=13&t=1410
3.Android App 1.6.4
1.Add imperial units.
2.Solve the issue of not being able to use line flight in some languages and "download error message"
3.You can send the flight log to us directly for further checking .
4.Error code Zino 0x0004
Solution:The Zino Gimbal reset video and picture
https://youtu.be/yKQ2-3T3zkY
5. Can I still cut rth off by a short press on the remote control RTH button when the Zino show disconnection during flight and start RTH ?
1. it can't cut RTH off by short press on the RTH button during RTH flight because of disconnection .
If the Zino Wifi connect again during RTH ,it will back to hover and not active RTH function.
6.Hubsan APP will no longer support the Android version below 5.0 on April 2019, because it will be too old and lead to a lot of use problems
7. There just have shape difference with the round camera (old version) and the square camera(Latest version),Not function difference
8.The Iphone 3.7.0 APP version released.
Add Imperial unit
Optimize transmitter connection tutorial
Add transmitter connection status reminder
9.Zino transmitter calibration
Push both sticks to the upper left corner and power on the transmitter simultaneously.rotate both sticks in circles for three times ,release both sticks,then press any button for 1.5 seconds until three quick Beep heard which indicates a successfful calibration.
10.Soft focus and compressed picture
The latest camera firmware ITV0.3.3 optimized this issue.
3.Android App 1.6.4
Add Imperial unit
