Can't pair the controller to the Drone-Solution
Re: Can't pair the controller to the Drone
I believe so. I’m recharging battery currently but will check. Why you ask?
When I updated the camera to version 0.3.3, I did not have a zino wifi network and I saw that the led was always on and that is not normal. After an hour of frustration, try once again to recharge 0.3.3 and it worked, it had wifi. My mistake, was the procedure of the update. Do not turn off the drone, and format the SD, from the Android app, and the red LED is fixed. So I did the same, but at the end of the update, turn off the zino, format the SD on the computer and everything went back to normal. I hope I can help you get out of your frustration.
Hello Jlat,
Thank Djose24 kindly suggestion
Kindly note if there have red light flashing near the SD slot,
If yes,turn Zino off,remove SD card,reformat to FAT 32 beforing updating the camera firmware then replace into Zino.
Djose24, you my friend are a genius! It’s back! Thanks manDjose24 wrote: ↑Mon Jan 14, 2019 9:34 pmWhen I updated the camera to version 0.3.3, I did not have a wifi network from the zino and I saw that the led was always on and that is not normal. After an hour of frustration, try once again to recharge 0.3.3 and it worked, I had wifi. My mistake, was the procedure of the update. Do not turn off the drone and from the android application format the sd and the red led is fixed. So I did the same, but at the end of the update, turn off the zino, format the SD on the computer and everything went back to normal. I hope to help you out of your frustration.
I'm very happy! Now fly and enjoy the zino like never before.
Well get this. I reformatted my SD Card to Fat32 then followed https://www.youtube.com/watch?v=YKv08SIFgbw
Turn on the drone.
Turn on the controller
open the app
Then connect the controller to the phone.
Now when I open the settings and goto the wifi connection the drone shows up every time.
Something so simple yet it stopped me using this drone for weeks.
Well thats my experience. Hope it helps
Turn on the drone.
open the app
Oh and make sure you wait till each element has fully turned on.
The drone.
The controller, all four lights on
Open the app and select Zino
Connect phone
Then connect wifi.....
The drone.
Connect phone
