Page 1 of 3
chargeur du Zino
Posted: Sat Jan 05, 2019 3:47 am
by Phildu17
Bonjour,
Comment peut on recharger la batterie avec un chargeur IMAX B6AC V2?
Merci
Re: chargeur du Zino
Posted: Sat Jan 05, 2019 4:06 am
by peterkng
You need to make an adapter cable | Vous devez faire un câble adaptateur
https://www.youtube.com/watch?v=NlTq_FWJTPA&t=600s
https://www.youtube.com/watch?v=Izw0hqTpq6w
Posted: Sat Jan 05, 2019 6:02 am
by fvdk
Posted: Sun Jan 06, 2019 3:19 am
by Phildu17
Merci pour l'info et la photo.
Posted: Mon Jan 07, 2019 7:49 am
by me_fa036eEZef
this cable would be worth ?? connecting the cables with a banana plug would it be fine?
Posted: Tue Jan 08, 2019 7:14 am
by fvdk
That is just the JST-XH female connector that goes into the balance port of your charger.
The other side of that cable should have a JST XH 4 Pin male connector with the 4 balance leads and the plus and minus main charging leads.
The charger should also be capable of charging LiHV batteries.
Posted: Tue Jan 08, 2019 12:08 pm
by irussphone
Nice, elegant solution...love it!
Posted: Tue Jan 08, 2019 1:19 pm
by Phildu17
Bonsoir,
Quel intérêt le "LIHV" par rapport au "LIPO"?
Merci
Posted: Tue Jan 08, 2019 3:19 pm
by fvdk
They are more powerful
Posted: Tue Jan 08, 2019 9:10 pm
by Djose24
Well done "fvdk". It is an alternative to the original charger. How long does the zino last in flight ?, and how much% of battery do you land?  I have the ibmax 6b and I may look at the one you say. Unless Hubsan takes out a reliable charger for two batteries that is good for me.
