The charger will give a balance connect error (at least mine does).me_70f32dlzEh wrote: ↑Sat Jan 12, 2019 5:11 amHi all,
I'm totally new, so be patient with me! What happens if in modyfing the cable I do not use the Jst cable to charge the battery but only the positive and negative cable? I mean: open the cable, find positive and negative, attach the banana plug and put it into the charger not using the balance charger output?
Thanks in advance
I also do not see why you would want to do that. The whole point of using a balance charger is to make sure that the cells will not get out of balance which in worst case scenario might result in a cell getting overcharged and explode.
It is very easy and cheap to make a balance adapter like the one in the photo, You can even do it without soldering if you use a ready made 3S balance extension cable and splice in the main charge leads. You can buy 5 of those extension cables on the Chinese websites for +/- €2.- shipped.
