chargeur du Zino
chargeur du Zino
Bonjour,
Comment peut on recharger la batterie avec un chargeur IMAX B6AC V2?
Merci
Merci
Re: chargeur du Zino
You need to make an adapter cable | Vous devez faire un câble adaptateur
https://www.youtube.com/watch?v=NlTq_FWJTPA&t=600s
https://www.youtube.com/watch?v=Izw0hqTpq6w
Merci pour l'info et la photo.
That is just the JST-XH female connector that goes into the balance port of your charger.
The other side of that cable should have a JST XH 4 Pin male connector with the 4 balance leads and the plus and minus main charging leads.
The charger should also be capable of charging LiHV batteries.
- irussphone
Nice, elegant solution...love it!
Bonsoir,
Quel intérêt le "LIHV" par rapport au "LIPO"?
Merci
Merci
Well done "fvdk". It is an alternative to the original charger. How long does the zino last in flight ?, and how much% of battery do you land? I have the ibmax 6b and I may look at the one you say. Unless Hubsan takes out a reliable charger for two batteries that is good for me.
