Zino A FC 1.0.46(new)
Posted: Fri Jan 04, 2019 10:17 pm
by Gregory
Is this the same as .46 that was released a few days ago or is it a new just release or refresh?
Re: Zino A FC 1.0.46(new)
Posted: Fri Jan 04, 2019 10:24 pm
by peterkng
All the files dates are the same, so I would say they are the same, they have only removed the elf file from the camera update that was confusing people.
Posted: Sat Jan 05, 2019 2:33 am
Hello Gregory,
The Zino FC 1.0.46 (NEW) released a few days ago is new one .
1. Delete the elf file.
2.Increased hovering stability
3.Increased aircraft adaptability at high latitude area
4.Optimized wind resistance
Posted: Sat Jan 05, 2019 5:11 am
by peterkng
Hubsan-Ailsa wrote: βSat Jan 05, 2019 2:33 am
Hello Gregory,
How
I just did a hash calculation on both release's files and they are binarily identical i.e. there is no difference. The only difference is the elf file has been removed from the latest zip file.
Ailsa mistakes by you like this one and the one the other day that the TX has a LiPo battery when it clearly has a 18650 Li-ion makes it difficult to trust what you have to say, you need to better check your facts.
Posted: Sat Jan 05, 2019 5:54 am
Hello peterkng,
Sorry for the inconvenience
The Zino TX Lipo battery model is 18650 Li-ion 2600mAh.
The Zino FC 1.0.46 I released on 27th Dec improved as attached below
1.Increased hovering stability
2.Increased aircraft adaptability at high latitude area
3.Optimized wind resistance
Posted: Sat Jan 05, 2019 7:08 am
by peterkng
Hubsan-Ailsa wrote: βSat Jan 05, 2019 5:54 am
Hello peterkng,
It must get lost in the translation from Chinese to English. A 18650 is not a lithium polymer battery (LiPo) is is a lithium-ion battery (Li-ion)
And the improvements
Are unchanged from the original 1.0.46 update
Posted: Sat Jan 05, 2019 8:51 am
by Gregory
Thanks for the clarification. I really appreciate it.
Posted: Sat Jan 05, 2019 3:14 pm
by me_157abXgZCo
peterkng wrote: βSat Jan 05, 2019 5:11 am
Hi Peterkng,
I am fully with you on that!
We can all see, that she is trying really hard, and staying friendly even when we are frustrated and with even angry language - very valuable. But Hubsan (in general) needs to learn, that communication needs to be fully fact driven and clear, in order to gain trustworthyness and be regarded as highly professional.
I think itβs quite obvious, that the 2 FW versions are the same, just a new distribution: same hashtag, exactly the same wording in description, ands on. If not - it would also be a desaster / showing non-professionalism, if they changed something, but kept the version number....
Regards, Hardy
Posted: Sat Jan 05, 2019 3:20 pm
by woo65
When 1.046 was published, the zip was called 1.046(new).
So its totally obvious that THERE IS NOT A NEW DISTRIBUTION.
Posted: Mon Jan 07, 2019 9:33 pm
by ge_504b6aPsfA
Early this morning before my coffee I updated to the [new]...I thought something wasn't quite right with this [new].....firmware...Bummer
