Rollback Firmware?
Rollback Firmware?
Post by irussphone » Thu Jan 03, 2019 9:37 am
This last update was good on everything but my camera...it now records with a dark Blue/Green overlay on photo/video on 2 out of my last three videos. My question is can I reinstall just the camera firmware update for 1.0.44 when the camera was working perfectly or do I have to install the whole 1.0.44 firmware with it?
ge_8efac33d06
Re: Rollback Firmware?
Post by ge_8efac33d06 » Thu Jan 03, 2019 5:13 pm
Did you try resetting the video settings on the App? It seems like you lost the red component of the RGB data. Could also be hardware related ... loose camera cable perhaps.
Post by irussphone » Fri Jan 04, 2019 1:02 am
Took video at home and it was fine in 1080p and 4K???
ge_8efac33d06
Post by ge_8efac33d06 » Fri Jan 04, 2019 2:06 am
Does your FPV show the same blue green overlay? Also, suggest you look at the low resolution version and see if you have the same problem.
Post by Hubsan-Ailsa » Fri Jan 04, 2019 2:21 am
Hello irussphone ,
Would you mind to provide the picture of the Zino firmware version in the APP for our reference?
Did you update the FC 1.0.46 , gimbal firmware and Zino IT V0.2.1.vb25 together?
