Page 1 of 4
How to increase the range of Zino?
Posted: Wed Jan 02, 2019 11:38 am
by me_3ce942yJox
After exceeding 250 m Zino is disconnected.
I can't fly more then this range.
Someone knows how to help me?
I am useing Android App.
Re: How to increase the range of Zino?
Posted: Wed Jan 02, 2019 1:02 pm
by isldoors
Need to do a antenna mod.?
Posted: Wed Jan 02, 2019 1:33 pm
by me_3ce942yJox
What do you mean " antena Mod." ?
Posted: Thu Jan 03, 2019 9:43 am
by irussphone
I have the DJI type wifi reflecting panels that fit over the existing antennas but I haven't tried any long flight trials until I'm more happy with the overall operation of the Zino. I got them at Banggood …
https://www.banggood.com/DJI-Phantom-3-Inspire-1-Transmitter-Antenna-Signal-Enhancement-Board-p-1015566.html?rmmds=detail-left-hotproducts__1&cur_warehouse=USA
Posted: Thu Jan 03, 2019 10:48 am
by jstremmler
Have a look here: https://www.aliexpress.com/item/for-Xiaomi-4k-Drone-Antenna-Refitting-Signal-Booster-8DB-Omni-7DB-Ori-Refit-Antenna-5km-Distance/32890133833.html?spm=2114.search0104.3.170.3f2d60e5Hl5Zml&ws_ab_test=searchweb0_0,searchweb201602_1_10320_10065_10068_10890_10547_319_10546_317_10548_10696_10084_453_454_10083_10618_10304_10307_10820_537_536_10843_10059_10884_10887_100031_321_322_10103,searchweb201603_6,ppcSwitch_0&algo_expid=e6158e68-fdb1-4d57-87f1-2f8dda1d883a-24&algo_pvid=e6158e68-fdb1-4d57-87f1-2f8dda1d883a
Posted: Thu Jan 03, 2019 2:39 pm
by me_fa036eEZef
me_3ce942yJox wrote: ↑Wed Jan 02, 2019 11:38 am
You only get 250 meters because you are connecting to the smartphone via Wi-Fi.
You have to connect by cable, the wifi disconnect it from the cell phone.
Posted: Thu Jan 03, 2019 3:14 pm
by me_3ce942yJox
Wi-Fi was turn off.
Posted: Fri Jan 04, 2019 1:59 pm
by me_075d7ydEYr
How do you guys get such long ranges? I've done two flights thus far with my Zino, and I get connection losses already at 40m altitude! I just ascended upwards from me, the video stream starts stuttering and eventually I get connection lost and the drone switches to RTH.
Note that I've never bound my phone's WiFi to Zino, so that shouldn't be an issue. I'm in a scarcely populated area so not that many Wi-Fi networks around (and certainly not running at 5.8GHz). During 15 mins of total flight time I've lost connection at least 4 times. The last flight I did with the Phone Wi-Fi turned off completely.
Posted: Fri Jan 04, 2019 2:25 pm
by woo65
First flight, 500 meters before losing connections, 50 meters high.
Posted: Fri Jan 04, 2019 9:43 pm
Hello me_075d7ydEYr ,
would you mind to try to fly the Zino to the further distance then rise to a certain altitude ?does it still have disconnection issue?
