To update or not to update?That is the question
Posted: Wed Jan 02, 2019 8:30 am
by Jlat
So my Zino is in route and I’ve been reading quite a few things about all the firmware updates. The good and the bad. My question to those of you who HAVE updated, what do you recommend upgrading and what should I stay away from. Thanks in advance!
Re: To update or not to update?That is the question
Posted: Wed Jan 02, 2019 9:32 am
by isldoors
Yes you should update but at this time I am going to wait
Until there is a better firmware .
Posted: Wed Jan 02, 2019 7:35 pm
by Jlat
isldoors wrote: ↑Wed Jan 02, 2019 9:32 am
Thanks for your input. Did you do any firmware updates(cam, gimbal, etc..) I’m reading and watching vids about all these color flashes and I’m a little weary about updating those.
Posted: Wed Jan 02, 2019 8:25 pm
by Djose24
When I received the zino I doubted it like you, but since everything started working correctly from the first day, I updated it and everything works fine. To think that they are improvements of firmware and now the turns and the stability are better thing than before were more abrupt.
Posted: Thu Jan 03, 2019 7:53 am
Hello all,
Kindly suggest you update all Zino firmware to the latest one .
Posted: Thu Jan 03, 2019 1:15 pm
by VinceCoetzee
If your drone comes and it works ok, don’t update your firmware as it seems to mess it up.
If it’s also problematic out the box, install new firmware, tell Ailsa it didn’t work and enjoy the endless ineffective suggestions until you can’t be bothered.
If it comes, works, even after the firmware update, I suggest playing the lottery, as you stand a good chance of winning
Posted: Thu Jan 03, 2019 4:48 pm
by Jlat
VinceCoetzee wrote: ↑Thu Jan 03, 2019 1:15 pm
Geez
Ok, well let’s see what condition mine is in when I get it. Are the camera/gimbal updates only to fix problems(flashing, gimbal error, etc...)or help with actual video quality?
Posted: Fri Jan 04, 2019 3:00 am
by VinceCoetzee
Jlat wrote: ↑Thu Jan 03, 2019 4:48 pm
Geez
I think it is to help with all you’ve mentioned there. Some people say it’s improved it and others say nothing is better, just more camera options in the app. Although I haven’t been able to test this since my drone doesn’t work.
Most issues are to do with the FC update. It was supposed to cure loss of altitude when turning, wind stability, toilet bowl effect and so on but I don’t know first hand as I can’t test it myself. My drone stopped connecting to rc after update and it won’t pair up again. I try flying it with my phone but it loses connection sporadically even if hovering.
I’m sure you’ll be fine mate, just don’t update firmware to the current available one, maybe wait for after
Posted: Fri Jan 04, 2019 3:11 am
Hello Jlat,
We will release the Zino IT firmware soon.,which will sove the picture issue.
Hello VinceCoetzee,
We will solve your issue as soon as possible
Posted: Fri Jan 04, 2019 9:05 am
by Jlat
Thanks Ailsa! Can you give us a projected release date of this new IT firmware? Also can you tell us if it will fix soft focus of the camera?
