Page 1 of 3
Zino Case
Posted: Tue Jan 01, 2019 6:17 pm
by irussphone
Zino will fit in a generic hand gun case from Academy Sports store...the brand is Plano and the model is protector. It cost $14.99. Here is a pic. Hopefully this will help those of you outside the United States to go find the brand in your favorite Sports and outdoor store.
Also check out the DJI reflectors that I got (knock offs) and they fit perfectly. I haven't used them yet in flight.
Re: Zino Case
Posted: Wed Jan 02, 2019 7:02 am
by Leducn
Find a case at Walmart
Re: Zino Case
Posted: Wed Jan 02, 2019 8:52 am
by irussphone
Nice!
Also, I used clear silicon rubber glue to glue down the foam to the plastic case so that it doesn't move when you take Zino in and out. Also used Foam-Tac glue to glue the two foam layers together. All worked pretty well and cheaply.
I wanted to store my Zino in unfolded configuration so that I minimize wear on the folding joints. I'm never going to backpack my drone anywhere anyway so full "spread eagle" design seemed the best way to go.
Re: Zino Case
Posted: Wed Jan 02, 2019 11:34 am
by me_fa036eEZef
Comment when you try the DJI repeaters.
Re: Zino Case
Posted: Wed Jan 02, 2019 2:02 pm
by irussphone
Will do.
Re: Zino Case
Posted: Thu Jan 03, 2019 1:15 pm
by me_88ef3U3VOi
I happened to have a camera bag I bought at a flea market that fits everything perfectly.
Holds the Zino, transmitter, four batteries, charger and cables with room for phone, manual, and extras.
Look around for a similar bag for 35mm camera.
Paid ten bucks.
Re: Zino Case
Posted: Fri Jan 04, 2019 4:03 am
Hello all,
Thanks for your sharing .
Do you have any good ideas or suggestion for the Zino cases?
Re: Zino Case
Posted: Fri Jan 04, 2019 4:07 am
by TwanBlack
Hello all,
Would like to see a full metal outside case with foam in the inside. Make it just a little bit bigger then the zino. Don't make it too big so it's easy to carry and doesn't have unnecessary space. (should also fit with controller, 2 extra batteries and propellors
Re: Zino Case
Posted: Fri Jan 04, 2019 7:00 am
by jstremmler
Have a look at the Hama borsa bag (only 24*24 cm) and see how the Zino fits in!
I had doubts about that, because the Zino has bigger dimensions...
https://www.youtube.com/watch?v=kkkmE-IqVgY
And here you can buy it at Amazon for €24.08 : https://www.amazon.de/Hama-abnehmbarer-Schultergurt-herausnehmbare-Drohnentasche/dp/B01KNP0RWC/ref=sr_1_3?ie=UTF8&qid=1546603174&sr=8-3&keywords=tasche+f%C3%BCr+drohne
Re: Zino Case
Posted: Fri Jan 04, 2019 7:20 am
Hello all,
Thanks for your kindly suggestion
I have forwarded all your suggestion and design ideas to related department.
