Zino Data Logger
- ge_8efac33d06
Zino Data Logger
I suggest to the Hubsan Team to add a realtime data logging function to the FC software that can record selected parameters at a selectable scan rate to the SD card for each flight. This will help immensely in the diagnosis and trouble shooting of odd behaviour and teething trouble. The datalogging function should be able to be armed and disabled from the APP. Parameters to be recorded, the scan rate etc should selectable from the APP. Data should be recorded to a flat file that is time stamped, comma or tab separated and with a MAC address identifying your unique drone. "Zinoists" should be able import this file into excel to graphically examine troublesome parameters and email their data to the Hubsan team for analysis. I'm sure there will be a lot more ideas and suggestions from other Zinoists on this topic.
Re: Zino Data Logger
Hello ge_8efac33d06 ,
Thanks for your kindly suggestion
I have forwarded your idea to R&D department.Further details will update in the Hubsan official forum.
Sincerely expected to more good ideas.
