Page 1 of 3
Android phone connected, no video feed?
Posted: Sat Dec 29, 2018 5:46 pm
by 152375952725700
Hello everyone,
Android phone version 5.0.2 connected with transmitter and drone with no problems, all is functional except for video feed from camera does not show up on screen. When changed to map view map shows up with no problem and I can see video feed through map bubble but when reversed I get a dark screen from the camera feed. Drone is updated with all latest firmware.V1.0.46
Any suggestions would be appreciated.
Thanks. ..
Re: Android phone connected, no video feed?
Posted: Sat Dec 29, 2018 6:40 pm
by peterkng
Check you have FPV On in your settings.
Posted: Sun Dec 30, 2018 12:14 pm
by 152375952725700
Yes, that didn't work.
I'm thinking the phone's usb setting is the issue, another post stated to use the USB charging mode, the only options I have are mtp and ptp, tried both,mtp is fine but for the video issue.
Thanks for the suggestion.
Posted: Sun Dec 30, 2018 12:21 pm
by gremaso
How about Camera permission to the X-Hubsan app in android?
- Screenshot_20181230-132202_Package installer.jpg (140.72 KiB) Viewed 11832 times
Posted: Sun Dec 30, 2018 1:16 pm
by 152375952725700
Yes , permissions are allowed. Still no go.
Posted: Sun Dec 30, 2018 4:35 pm
by peterkng
OTG is enabled? My old Android 5.1.1 phone has an option to turn OTG on and off.
Posted: Sun Dec 30, 2018 6:17 pm
by 152375952725700
I don't see an on-and-off option but checked with otg checker app says phone OTG is enabled.
Posted: Sun Dec 30, 2018 7:12 pm
by peterkng
152375952725700 wrote: ↑Sun Dec 30, 2018 6:17 pm
Sorry I am out of ideas, can you borrow a newer phone and test with it so you can rule out a Zino or controller issue rather than a phone issue
Posted: Sun Dec 30, 2018 7:58 pm
by 152375952725700
Yes,I'll try that and let you know.
Thanks for all the suggestions.
Posted: Wed Jan 02, 2019 5:02 am
Hello 152375952725700,
Did you try to change another phone to connect the transmitter?I will email you for further checking.
Thank peterkng and gremaso kindly suggestion
