Zino FC 1.0.46
Re: Zino FC 1.0.46
Dear Ailsa,
Today Zino arrived, firmware was as follows.
FC: V 1.0.44
Camera: IT_V0.2.1.ub25
Gimbal: G_V 3.0.2.1
It's the latest version except FC, can I only update FC without Camera and Gimbal update?
FC: V 1.0.44
Gimbal: G_V 3.0.2.1
Re: Zino FC 1.0.46
Did the new f/w update. Helped stabilization at low altitude. We have 12-15 mph winds here today. It held very well.
Gimbal. It seems so much smoother. No jello. BUT......those with the jello should check their props. The individual leaves on the propellers are a little loose. The shaft that the screws go thru seems just a "tad"to big. I feel a bushing of some sort would help this.
Re: Zino FC 1.0.46
Already perform the upgrade:
HUBSAN_Zino-A_FC_V1.0.46.hbs and
ZINO_G_V3.0.2.1.gbl
But...
The video speaks only of 2 files to place in the SD memory ?:
AmbaSysFW and Asd_md5 ...
What to do with the file:
Zino_IT_V0.2.1.ub25.elf ?
Tnks.
ZINO_G_V3.0.2.1.gbl
But...
Tnks.
Re: Zino FC 1.0.46
Elf file is not used.
Gimbal can't be better than before, BECAUSE GIMBLE FW HAS NOT BE CHANGED.
Btw, gimble do its dirty job quite well.
Re: Zino FC 1.0.46
Everything was done without problems..
Thank you.
...Dirty Gimble
Thank you.
...Dirty Gimble
Re: Zino FC 1.0.46
Always update all the firmware in a release package even if the version numbers of some of the firmare are the same as previous.
E.G. as in this release the FC firmware is a different version but the Gimbal and Camera versions are the same. Sometimes programers need to make references changes in the code for the other firmware and recompile without changing the version. This does not appear to be the case in this instance as the compile dates of the older firmware has not changed. But it is a good habit to get into of updating everything as a full package and not pick and choose.
Re: Zino FC 1.0.46
I upgraded all the 3 infact, but obviously i m not expecting gimbal or camera improvement.
Re: Zino FC 1.0.46
Yes, sadly that will require actual version updates
Well after testing this firmware it does seem more stable and a bit less sensitive to controller input. Still not as subtle as I would like (e.g like my 501SS) especially when trying to land in a tight space or back on my landing mat with a crosswind but way better than 1.0.44.
Re: Zino FC 1.0.46
The update focus on solving the TB issue.
Atleast Hubsan makes solution to keep our Zino fly safe.
Im sure next priority to he heard is the camera improvement.
Good Job Team Hubsan...
