Hubsan app ANDROID
Hubsan app ANDROID
Hi.
I would like to know if they plan to translate the Hubsan app into Spanish and if so, when it will be updated.
Re: Hubsan app ANDROID
It would be nice an update of the app to Spanish, and that would include being able to set the exponential to personalize the movement as the yaw that is still very sensitive in manual and automatic points.
Hello me_fa036eEZef.
I have forward your suggestion to related department.will update APP android in Spanish in the furture.
Another problem of the app on android. The flight log does not give me the map or the movement. I get no GPS signal. The flight the GPS worked perfectly for me.
Tested with 3 older smartphones:
- Android 4.4: Appcrash at "Enter Main Menu"
- Android 5.1: No WiFi connection, display is upside down. In some menus it turns, but when leaving it turns back.
- Android 6: Works, but the automatic on/off of the GPS sensor (like some navigation apps do) is not.
diet01109 wrote: ↑Mon Dec 24, 2018 4:34 pmTested with 3 older smartphones:
Question. What version of X-Hubsan do you have installed on your Android 4.4 smartphone?
Just out of interest I wanted to test this, but on my old smartphone running Android 4.4.4 the latest version of X-Hubsan that I get is 1.5.0, which doesn't support the Zino yet.
I had ran into this problem when my app updated and what I did was I got into my phone settings and checked the app permissions and found that the X Hubsan didn't have any so I gave it permission to location,media and phone and it has worked fine from that point on. Hope this helps.diet01109 wrote: ↑Mon Dec 24, 2018 4:34 pmTested with 3 older smartphones:
I believe,I may be wrong,but the FPV function is if you put your phone in a set of goggles,it splits the screen.
Android is V 4.4.2. X-Hubsan (fresh installed) is V 1.6.3.fb_43b9ftbKWM wrote: ↑Mon Dec 24, 2018 7:39 pm[... Question. What version of X-Hubsan do you have installed on your Android 4.4 smartphone?
At other older SP with Android 4.2.2 Playstore says "Not suitable for this unit".
I still have this problem.me_fa036eEZef wrote: ↑Mon Dec 24, 2018 1:46 pmAnother problem of the app on android. The flight log does not give me the map or the movement. I get no GPS signal. The flight the GPS worked perfectly for me.
I fly the drone without problems, but the flight log does not work well for me.
It shows no map, no movement of the drone.
it does not keep records either.
how do I solve it??
I'm an android, but the phone is good with the remote.
