Compass Calibration & Toilet Bowl Effect
Posted: Thu Dec 20, 2018 11:10 am
by dogstar7
Continuing problems with compass calibrations?
Toilet bowl effect above 20 meters
New firmware installed. Nothing seems to help
Re: Compass Calibration & Toilet Bowl Effect
Posted: Thu Dec 20, 2018 11:45 am
by Gregory
Same here. I am going to wait until they release a new firmware update or I might reinstall the previous update.
Posted: Thu Dec 20, 2018 11:57 am
by DonHeintz
I've seen several people say they will or did go back to the original firmware. I really don't care about the video resolution selection cause I will probably use the 4K setting. I would like to go back to the original software. I don't think you can roll it back so you would need to have a copy of it. Where would you get it?
Posted: Thu Dec 20, 2018 12:29 pm
by Gregory
I'm not sure how you would get the original, but at least I could fly with the previous version 1.0.43 and I still have that on my computer.
I am going to try to reinstall the latest version one more time before I go back.
Posted: Thu Dec 20, 2018 1:46 pm
by MrDronenut
T.B is caused by a faulty compass calibration,it has nothing to do with firmware.
I've done all the updates,and have no problem at all.
My suggestion:
Get a real compass,sit it beside Zino,with compass pointing north. Open Zino app and look at the "yaw"on bottom right of screen. If it's more than a degree or 2 off,your quad needs calibrated.
Do an OUTSIDE calibration until the compass and Zino,when both are pointing north,read "yaw"and see what it reads.
Posted: Thu Dec 20, 2018 9:38 pm
by Macscope
Ah man not you too i thought you got one of the grade A Zino's you got good videos yeah my problems stared after the update so i will try
what the guy up there suggest lol
Posted: Fri Dec 21, 2018 1:29 am
Hello all,
Thank rDronenut good suggestion
Kindly note the value"H "and "'Yaw" is the same before take off.
Hope will help you solve this Toilet Bowl effect.
If still fail to work ,would you mind to provide the flight log screen recording for us?
Posted: Fri Dec 21, 2018 8:18 pm
by Gregory
My suggestion:
Thank you for this information, it took 8 times to get it close and I'm still off by 3 or 4 degrees and I can fly it but it still has periods that it acts like it lost and starts to TB but straightens up as soon as I give it input.
What I don't understand is how my Visau xs812 GPS with a barometer that cost less than $100.00 is rock solid and doesn't wonder around and the Zino at it's price can't.
Hopefully Hubsan will get it corrected and turn this into a auwsom bird.
