THE ZINO DOES NOT HAVE A 4K CAMERA !!!!!!!!!!
https://www.youtube.com/watch?v=uOVrUnsK8YM&t=146s In this video the Guy is adamant THE ZINO DOES NOT HAVE A 4K CAMERA, your comments please
Re: THE ZINO DOES NOT HAVE A 4K CAMERA !!!!!!!!!!
He's also adamant that he can walk on water.droneflyers wrote: ↑Wed Dec 19, 2018 10:40 amhttps://www.youtube.com/watch?v=uOVrUnsK8YM&t=146s In this video the Guy is adamant THE ZINO DOES NOT HAVE A 4K CAMERA, your comments please
That about sums it, and the video up...
This is the reply I got from him in the comments of his vid
He is a twat and talks cr@pI am confused, you say it is not a 4k camera but doesn't it uses an Ambarella Sport Camera chip which is an 8 megapixel chip i.e. 3840x2160
Reply 2
Hubsan QC Help & Support1 day ago
Put a big block in a VW does it make it a corvette?
Reply 1
No but it makes it a V8
- irussphone
If I worked for Hubsan, I would sue him over his YouTube channel name. I'm guessing he is NOT affiliated with Hubsan in any way.
I guess this is true. I have taken several videos and they always take two videos with one at 3840 x 2160 and the second video at 768 x 432. Real 4K is 4096 x 2160 while 3840 x 2160 is considered a lower resolution called Ultra HD. I looked at the DJI pro and their specs show a C4K resolution at 4096×2160 24p and a 4K resolution at 3840×2160 24/25/30p which is what the Zino is. I also read that a lot of TV's advertise 4K resolution but are actually at the 3840×2160 resolution so it isn't just the Zino.droneflyers wrote: ↑Wed Dec 19, 2018 10:40 amhttps://www.youtube.com/watch?v=uOVrUnsK8YM&t=146s In this video the Guy is adamant THE ZINO DOES NOT HAVE A 4K CAMERA, your comments please
The 2 resolutions are 4K. The 4K cinema and the 4K UHD. The Youtubeur does not master this nuance!
so..i am movie director and i always work with camera..light..so u better then director of photography or movie director know about camera..so..for my side i tell you a honest and true consideration about the zino camera..for my side is not 4k..and is not uhd format..for my side...this is a 1080p camera with 80mbps upscaled by software interpolation in uhd format..for 2 reason..first..if it was a real 4k 4096x2160 resolution like my red epic and blackmagic you will notice up the screen a very small black bar and quality also in low bitrate is extremly good...now we talk on uhd..this camera can give you in the info the resolution of uhd..but is not..because uhd quality also in low bitrate is not poor like this but you will notice a lot of detail especialy in the three and building..and this camera doesn't not..so for my side this camera is full hd 1920x1080 with bitrate like 80mbps or somethink similar and with software the upscale the image to 3840x2160...this is all..so the guy tell the true..this camera is not recording 4k...this camera is not recording uhd...this camera record full hd good quality and converter by interpolation in uhd
Better stick to your movie making then cause you know nothing about electronics or how video is encoded in a camera. The Hubsan Zino uses an 11x11 mm 8 megapixel chip which is 4k there is no upscaling to get to 4K it is already 4K 3840x2160 i.e 8,294,400 pixels. A Red Epic typically is a 5k camera with a 14 megapixel chip i.e. 5120 × 2700ClaudioLisco wrote: ↑Wed Dec 19, 2018 5:25 pmso..i am movie director and i always work with camera..light..so u better then director of photography or movie director know about camera..so..for my side i tell you a honest and true consideration about the zino camera..for my side is not 4k..and is not uhd format..for my side...this is a 1080p camera with 80mbps upscaled by software interpolation in uhd format..for 2 reason..first..if it was a real 4k 4096x2160 resolution like my red epic and blackmagic you will notice up the screen a very small black bar and quality also in low bitrate is extremly good...now we talk on uhd..this camera can give you in the info the resolution of uhd..but is not..because uhd quality also in low bitrate is not poor like this but you will notice a lot of detail especialy in the three and building..and this camera doesn't not..so for my side this camera is full hd 1920x1080 with bitrate like 80mbps or somethink similar and with software the upscale the image to 3840x2160...this is all..so the guy tell the true..this camera is not recording 4k...this camera is not recording uhd...this camera record full hd good quality and converter by interpolation in uhd
The full Specs of the Red Epic sensor
SENSOR SPECIFICS
Sensor Size:
Super 35mm - Equivalent to S35mm (Motion)/APS-H (Still) lenses
Sensor Type:
CMOS - 14 Megapixel MYSTERIUM-X®
Signal-to-Noise Ratio:
66 dB
Sensor Dimensions:
27.7 mm (h) x 14.6 mm (v) = 31.4 mm (d)
CAMERA
Recording Formats:
2K Full Format - 240 fps (2048 × 1080); 300 fps at 2K 2.4:1 (2048 × 864)
3K Full Format - 150 fps (3072 × 1620); 200 fps at 3K 2.4:1 (3072 × 1296)
4K Full Format - 120 fps (4096 × 2160); 150 fps at 4K 2.4:1 (4096 × 1728)
5K Full Format - 96 fps (5120 × 2700); 120 fps at 5K 2.4:1 (5120 × 2160)
The Zino is a cheap action cam, not a cinematic camera so compare apples with apples.
It is what it is and it is 4k.
Hello all,
The Zino is indeed 4k.
You can check if it is right when you received Zino.
We will know that you are "director" !!! Lollll.ClaudioLisco wrote: ↑Wed Dec 19, 2018 5:25 pmso..i am movie director and i always work with camera..light..so u better then director of photography or movie director know about camera..so..for my side i tell you a honest and true consideration about the zino camera..for my side is not 4k..and is not uhd format..for my side...this is a 1080p camera with 80mbps upscaled by software interpolation in uhd format..for 2 reason..first..if it was a real 4k 4096x2160 resolution like my red epic and blackmagic you will notice up the screen a very small black bar and quality also in low bitrate is extremly good...now we talk on uhd..this camera can give you in the info the resolution of uhd..but is not..because uhd quality also in low bitrate is not poor like this but you will notice a lot of detail especialy in the three and building..and this camera doesn't not..so for my side this camera is full hd 1920x1080 with bitrate like 80mbps or somethink similar and with software the upscale the image to 3840x2160...this is all..so the guy tell the true..this camera is not recording 4k...this camera is not recording uhd...this camera record full hd good quality and converter by interpolation in uhd
So, just do it and do not judge things that you can not control!
ZINO is a 4K, not a 4K "cinema" but a 4K UHD.
Good continuation in realization ....
