Maximum specs for Zino memory card
Posted: Wed Dec 19, 2018 10:19 am
by TwanBlack
Hi,
I was wondering; what are the maximum specs memory card a Zino can handle? I've read 128GB max, but what are the other max and minimal specs?
Re: Maximum specs for Zino memory card
Posted: Wed Dec 19, 2018 10:48 am
by irussphone
Yes Hubsan has said 128gb max. I have one. The other spec is a speed of "U3" which will have the 3 inside of the U. I believe that is the fastest spec right now.
Posted: Wed Dec 19, 2018 11:14 am
by TwanBlack
Which card did you purchase?
Posted: Wed Dec 19, 2018 11:36 am
by Djose24
I used a 16g class 10 card today. I was great, the only thing I see is that I recorded the video twice in bad quality and the other in the quality that I select. And engraved in various qualities.
Posted: Wed Dec 19, 2018 12:23 pm
by fb_43b9ftbKWM
Hi,
It's been said somewhere that the Zino's camera is based on the Ambarella A12S chip. According to the spec document of the A12S it has "SDXC™ / UHS-1 support". So the Zino would definitely not support anything above that (like SDUC or UHS-II).
By specification, SDXC supports SD card sizes up to 2048 GB.
However, this is still no guarantee that any microSDXC card up to 2048 GB works with the Zino.
Personally I would not go and spend money on a 256 GB or bigger microSD card specifically for use with the Zino, unless someone else who already owns such a card has successfully tested this combination.
Posted: Wed Dec 19, 2018 12:58 pm
by irussphone
I have the Samsung U3 128GB SD card. Got it on Amazon for around $20. Will hold a ton of video.
