Hi,
I was wondering; what are the maximum specs memory card a Zino can handle? I've read 128GB max, but what are the other max and minimal specs?
Maximum specs for Zino memory card
- irussphone
Re: Maximum specs for Zino memory card
Yes Hubsan has said 128gb max. I have one. The other spec is a speed of "U3" which will have the 3 inside of the U. I believe that is the fastest spec right now.
Which card did you purchase?irussphone wrote: ↑Wed Dec 19, 2018 10:48 amYes Hubsan has said 128gb max. I have one. The other spec is a speed of "U3" which will have the 3 inside of the U. I believe that is the fastest spec right now.
I used a 16g class 10 card today. I was great, the only thing I see is that I recorded the video twice in bad quality and the other in the quality that I select. And engraved in various qualities.
It's been said somewhere that the Zino's camera is based on the Ambarella A12S chip. According to the spec document of the A12S it has "SDXC™ / UHS-1 support". So the Zino would definitely not support anything above that (like SDUC or UHS-II).
By specification, SDXC supports SD card sizes up to 2048 GB.
However, this is still no guarantee that any microSDXC card up to 2048 GB works with the Zino.
Personally I would not go and spend money on a 256 GB or bigger microSD card specifically for use with the Zino, unless someone else who already owns such a card has successfully tested this combination.
- irussphone
I have the Samsung U3 128GB SD card. Got it on Amazon for around $20. Will hold a ton of video.TwanBlack wrote: ↑Wed Dec 19, 2018 11:14 amWhich card did you purchase?irussphone wrote: ↑Wed Dec 19, 2018 10:48 amYes Hubsan has said 128gb max. I have one. The other spec is a speed of "U3" which will have the 3 inside of the U. I believe that is the fastest spec right now.
