Page 1 of 7
Pink & Yellow Flashes in recorded video
Posted: Tue Dec 18, 2018 5:07 pm
by JMCP
Hi everyone,
I tried the Zino for the first time and everything was fine, it was really stable and precise, connected to 12 satellites with high-clouds weather and I didnt have any problem with the flight.
The only issue I found so far was in the recording. In the 6 minute video I recorded I can appreciate some 'blinking' in which the image turns yellow or pink, for less than a second and then it corrects automatically. It appears several times in the video, at least 10. The video was in 4K and I used a high quality MicroSD with 64Gb, class 10 with up to 60 Mb/s writting.
I dont know yet if this could be an issue of camera firmware, the format of the video or if I received a defective unit.
I will update with more info when I record again in 4K and 1080P
Thanks
Re: Purple & Yellow Image in recorded video
Posted: Tue Dec 18, 2018 5:17 pm
by woo65
I've done a second video (before upgrading fw, now drone can't connect with phone), and had the same issue...
Posted: Tue Dec 18, 2018 5:21 pm
by JMCP
Yeah I hope that this is a firmware issue that can be solved with an update, otherwise I will think about returning the Zino if there is no easy solution...
Re: Purple & Yellow Blinking Image in recorded video
Posted: Wed Dec 19, 2018 6:09 am
Hello JMCP ,
I have forwarded your issue to our engineer.will email you.
Posted: Wed Dec 19, 2018 6:22 am
by JMCP
Hello JMCP ,
Thank you!!
Posted: Wed Dec 19, 2018 9:24 am
by MrDronenut
Hello JMCP ,
I also have the flashes. Not a lot,but 5-6 times. Please let me know the answer.
Posted: Wed Dec 19, 2018 11:06 am
by 3108vibhash
Same here , got flashes during last flight. When fix is available please let us know.
Posted: Wed Dec 19, 2018 12:36 pm
by robmwpropane
Same issue here;
https://forum.hubsan.com/viewtopic.php?f=13&t=1194
Posted: Fri Dec 21, 2018 9:21 am
by JMCP
Hello JMCP ,
Okay so today I tried recording again and the same thing happens. Both in 4K and 1080 60fps. There are pink, yellow and black flashing images both in the recorded video and the fpv.
I am still waiting for the email. Any clue if this is an issue that can be solved with software updates or a hardware problem?
I need to know because I am thinking about returning it for a refund.
Thank you
Re: Pink & Yellow Blinking Image in recorded video
Posted: Fri Dec 21, 2018 10:42 am
by gsdipo
I am having the same issues with my Zeno. I've had this issue all along but it seems after the last update it's more frequent. I am getting pink and yellow flashes at random while taking video. It happens two or three times in a 5 minute flight and the next flight seven or eight times. I have noticed it seems to happen on a sunny day and when the camera is trying to change exposure. An example is when you turn from Shadow area into brighter light, especially if you turn in the direction of the Sun. When it's very cloudy, I have taking video without a single pink or yellow flash.
