After update, Zino will not pair to controller or show network
Posted: Mon Dec 17, 2018 6:07 pm
I received the Zino which initially worked with no issue, without enabling USB Debugging.
Paired to transmitter with no problem and first flight was a success.
I did not note the version of android application, or any other versions as I was not expecting any issues.
However, I decided to update the Zino after seeing your update video and followed all of the steps in the same order as shown in video.
I then updated the application to most recent Google Play Version 1.6.3
The Transmitter is recognised by the application but no network appears under "Controls" > "Set Transmitter and aircraft connection" even after multiple refreshes.
I have since tried following, this new Android guide: https://forum.hubsan.com/download/file.php?id=37 which involves enabling USB debugging.
(Really, that should not be the default method in future, very insecure for users.)
I have tried redoing each step of the update and for the part with the SD update, using different SD Cards. (3 SD cards, two high speed 64gb and 128gb + 1 4gb slow card)
Outside the application, I cannot find a Zino network on two android devices or a Macbook (Unsure if a mac would detect it)
Things to rule out:
There does not seem to be a method to reset the Zino, though the nice representative in chat told me an engineer may have access to an old firmware.
Which, at this point I would be nervous trying a rollback.
I am a long time customer with no previous issues.
I feel like an idiot telling so many of my friends about, only to say on Monday that I have no footage and drone does not work after one flight.
Hoping a resolution can be found soon for this as I was happy to see Hubsan maturing as a company with this product.
I love an underdog, don't want to revert to DJI Spark or other big name brand.
Currently awaiting a response...
- ZINO V.1.0.43 (firmware for flight control board)
- ZINO_G-V3.0.2.1 (firmware for gimbal)
- ZINO_IT-V0.2.1.ub25(firmware for camera board)
Things to rule out:
- USB C Cable (Worked first flight)
- Mobile Device itself, LG G6 on Oreo (Worked first flight, no changes in between)
- Transmitter (Was not updated, no file in download or instructions to update so cannot attempt.)
Shows: Model HT016B Hardware Version 1.0.0 Transmitter Version HT016B_RP_V0.1.1
