you need a super gsm for the zino
Posted: Sun Dec 16, 2018 4:41 pm
by Sparty3108
hello hubsan what should i understand that my samsung A6 + 2 months only is a bad phone for zino. see photos????
impossible to make flights in radius and full sky as well as other anomaly to see attached ... ??????
the application not at the point at all.
frankly a goodbye
help help hubsan
Re: you need a super gsm for the zino
Posted: Sun Dec 16, 2018 9:38 pm
by peterkng
The A6 is a mid spec phone and should be able to run the Hubsan app, make certain all background apps are off before using it with your Zino.
Posted: Mon Dec 17, 2018 2:03 am
by Sparty3108
by peterkng » Mon Dec 17, 2018 3:38 am
Thank you for your reply
for stealing on the shelf I have attached an anomaly if you can help me to decipher? : D
thanks again
Posted: Mon Dec 17, 2018 2:32 am
by akifoktar
Object tracking is operated by app. App process the image and move the drone. İmage processing job takes too much system sources. İ recommend close all aplications background.
Posted: Mon Dec 17, 2018 2:46 am
Hello Sparty3108 ,
If the phone is hot and the CPU is not moving when engage the image tracking .The APP will have anomaly .which means the mobile device CPU is fully loaded, Kindly recommended to turn off the image tracking function.
Waiting for your further feedback
Posted: Mon Dec 17, 2018 3:35 am
by peterkng
From the look of the log you had a Floating Point Error in Java on the Hubsan App. If it happens continually try uninstalling and reinstalling the app. Otherwise it might just be a random crash.
Posted: Tue Dec 18, 2018 2:31 am
by Sparty3108
thank you for your answers to all 2
I have already tried several times the "LINE FLY MODE" it was every time ANOMALY and also that 1 of the 3 panorama mode ???
I do not know if it's a processor problem for the "Follow mode active track" I agree especially as a message indicates.
I'm very zino cash but his little problems a bit sorry me.
I have everything set in order before takeoff. google maps is ok.
I do not understand?
thanks for hard work
Gabriel
youtube "Gabe Sparty"
Posted: Sat Dec 22, 2018 7:40 am
by Sparty3108
i try ......a lot .......a lot .....a lot evrytime the same message.
my Cpu ok and the message come again that the cpu is bad??????
