updating zino
updating zino
Good day, I have updated the zino correctly following the tutorial but now I can not in any way to connect it to the command. Zino is not detected in any way impossible to connect it. I tried again to install updates but nothing. Before it worked regularly. What can I do?
Re: updating zino
I would guess you have "bricked "it.
Only solution............new quad
Re: updating zino
Great way to help him out.MrDronenut wrote: ↑Thu Dec 13, 2018 12:19 pmI would guess you have "bricked "it.
I am sure the support can help you. It is rare to really "brick" something nowadays.
Re: updating zino
Hello gherardo ,
May I know which firmware did you update?IT or FC or Gimbal firmware?
Re: updating zino
It sounds like we may have the same issue, but your description is a little vague
https://forum.hubsan.com/viewtopic.php?f=13&t=1243
gherardo wrote: ↑Thu Dec 13, 2018 11:08 amGood day, I have updated the zino correctly following the tutorial but now I can not in any way to connect it to the command. Zino is not detected in any way impossible to connect it. I tried again to install updates but nothing. Before it worked regularly. What can I do?
Re: updating zino
https://forum.hubsan.com/viewtopic.php?f=13&t=1232
