Zino Latest firmware
Dear Zino Fans,
Zino latest firmware has released on the Hubsan official website.
https://www.hubsan.com/na/index.php?main_page=support
Zino latest firmware change log
1. Improved the stability of ZINO.
2. Improved the wind resistance &the GPS hovering accuracy
3. Improved the camera controls for tilting up and down and make it more smoothly
4. Support 2.7K, 1080P, 720P video recording
5. Adjustable IOS white balance
After updating the Zino latest firmware.Kindly update the Android or IOS app to the latest one
Re: Zino Latest firmware
good! but ....
Where is upgrade tool for MAC please ?
The link for the download does not appear on my Safari browserHubsan-Ailsa wrote: ↑Mon Dec 10, 2018 8:03 amDear Zino Fans,
Dear Magnum1956PMQ ,
The firmware only work for Windows at present
30% of persons are on MAC !!Hubsan-Ailsa wrote: ↑Mon Dec 10, 2018 8:38 amDear Magnum1956PMQ ,
All good. Upgrade complete and now recording in 1080p. The change log also shows a transmitter firmware upgrade but there is no file or process. People you should always have a pc handy. You could always use virtual box and run windows on your macs.
I jumped the gun. The link just appeared in the last few minutes on my Safari browser
Can't wait to install it...but will have to due to the incursion of real life issues such as going to work and the like...
I'm on Windows and the file won't open , is there a program to open file or read it ????????????
It fixes some of the more common problems but one: it's too much sensitive on the sticks and there is no difference between sport and normal. I guess it's in sport mode by default, maybe it's better to add a slower normal move or a way to set the speed by the app. Hope to have this fix too soon
edit: I forgot another problem to fix: the return to home function has to be deactivated by users, the drone can land in wrong place and user must control it any time
I just downloaded the firmware.zip file and decompress it and there are all the files needed, in the FC-V1.0.43 folder there is a .exe file that I launched and correctly opened so it works. See the video on how to flash the files in the zino
