Now my gimbal wont work
Posted: Sun Dec 09, 2018 5:05 am
by SkillPig
Says gimbal protection in the app all the time. Any ideas?
Re: Now my gimbal wont work
Posted: Sun Dec 09, 2018 5:12 am
by SkillPig
Error x4
Posted: Sun Dec 09, 2018 11:02 am
by ClaudioLisco
Because you have to remove protection from gimbal before to switch on You risk ti crash your gimbal before start to use a drone learn how to use it
Posted: Sun Dec 09, 2018 11:28 am
by SkillPig
I appreciate the help mate, but ofc I took the gimbal cover off! Any other advice? Ive obvs done all re calibrations
Posted: Sun Dec 09, 2018 11:41 am
by 3108vibhash
Did you try resetting zino..turn off ..remove battery and reconnecting it again? I removed gimbal cover after zino is turned on gimbal wont work, restarted it and gimbal worked fine.
Posted: Sun Dec 09, 2018 11:51 am
by SkillPig
So the gimbal starts to work at about 25 degrees pitch/yaw. Any less and it thinks the gimbal cover is on??? Cmon Hubsan - I know Im not the only one
Posted: Sun Dec 09, 2018 11:52 am
by SkillPig
Sent you a PM 3108vibhash - you got nothing other than take the cover off and learn to fly your drone?????? (Sorry - just got your response - ty)
Posted: Sun Dec 09, 2018 11:57 am
by MrDronenut
This quad has a built in feature called "gimbal lock". If the quad crashes,or is tilted more than 90 degrees,the gimbal locks so it won't be damaged.
Reboot your quad.
Posted: Sun Dec 09, 2018 12:26 pm
by SkillPig
Reboot your quad.
Ive rebooted and pulled the battery many times today - the problem persists - any other ideas?
Posted: Sun Dec 09, 2018 12:27 pm
by 3108vibhash
Cannot think of other options. Hopefully Hubsan will be able top help you to fix it.
