Now my gimbal wont work
Says gimbal protection in the app all the time. Any ideas?
Re: Now my gimbal wont work
Because you have to remove protection from gimbal before to switch on You risk ti crash your gimbal before start to use a drone learn how to use it
I appreciate the help mate, but ofc I took the gimbal cover off! Any other advice? Ive obvs done all re calibrations
Did you try resetting zino..turn off ..remove battery and reconnecting it again? I removed gimbal cover after zino is turned on gimbal wont work, restarted it and gimbal worked fine.
So the gimbal starts to work at about 25 degrees pitch/yaw. Any less and it thinks the gimbal cover is on??? Cmon Hubsan - I know Im not the only one
Sent you a PM 3108vibhash - you got nothing other than take the cover off and learn to fly your drone?????? (Sorry - just got your response - ty)
This quad has a built in feature called "gimbal lock". If the quad crashes,or is tilted more than 90 degrees,the gimbal locks so it won't be damaged.
Reboot your quad.
Reboot your quad.
Ive rebooted and pulled the battery many times today - the problem persists - any other ideas?MrDronenut wrote: ↑Sun Dec 09, 2018 11:57 amThis quad has a built in feature called "gimbal lock". If the quad crashes,or is tilted more than 90 degrees,the gimbal locks so it won't be damaged.
Reboot your quad.
Cannot think of other options. Hopefully Hubsan will be able top help you to fix it.
