Video Bitrate Real World Experience
Hubsan quotes the bitrate as 60mbits/s anyone reaching those bitrates in the real world?
Re: Video Bitrate Real World Experience
Camera settings will be active after firmware update on 10th of dec
Sorry, but this has nothing to do with camera settings. This is about how much data the camera actually records. We have seen time and again from reviewers that they get about 44-45 mbits/s. But Hubsan told me it should record at 60mbits (in 4k of course). The question I have is what are people who have the Zino already seeing?
Not what the camera settings will be, which other than the resolution settings, won't change how much information the sensor will be able to record.
Also getting 44mbps. I think that wont change with updates.
Sad, Hubsan says it is supposed to be 60mbps. I hope they don't count the extra video that is recorded along with the 4k one.3108vibhash wrote: ↑Sat Dec 08, 2018 8:00 amAlso getting 44mbps. I think that wont change with updates.
How much the sensor is capable of recording and how much the processor is currently recording to the SD card can indeed be adjusted in the firmware upgrade.
The simple answer is no, as of this date 44mbs is what is being recorded to the card.
What the processor will write to the card after the upgrade has yet to be seen.
For instance, the 60fps setting has not yet been addressed in the app
The fact that the Hubsan tutorial tells you to install the first upgrade before powering up the craft indicates this upgrade will reset the CPU at the machine language level which can reset the bit rate throughput in the image processor
