Solution -Lose wifi signal and lose connection
me_d3873xYJjO
Re: Solution -Lose wifi signal and lose connection
Post by me_d3873xYJjO » Wed Jan 23, 2019 5:46 am
VinceCoetzee wrote:
Fri Jan 04, 2019 7:34 am
What micro sd card do you recommend? Because if you suggest using a different card then it might mean that some aren’t compatible with the Zino.
FAT32 has a maximum partition size of 32GB. Therefore, cards with larger storage sizes will only support exFAT and NTFS natively.
In conclusion, use 32GB cards or smaller to upgrade firmwares on the Zino :)
