Zino major issues. No wifi showing or connecting
ge_8efac33d06
Re: Zino major issues. No wifi showing or connecting
Post by ge_8efac33d06 » Thu Jan 03, 2019 5:08 pm
For those with connection issues, The FC V1.0.46 upgrade expects the camera software to be upgraded too. See my previous post below that worked for me :
Yesterday I had the same exact problem. I removed the SD card and then the Zino would connect again. If I reinstalled the SD card, the connection would fail. I then updated the camera software, removed all the files on SD card and retried. On the first go, the connection failed. The second try at connecting was successful. It seems that the Zino expects a camera upgrade and tries to read the upgrade off the SD card continuously regardless of whether its there or not and doesn't wake up the wifi subsystem.
Good luck.
Post by Hubsan-Ailsa » Fri Jan 04, 2019 2:56 am
Hello VinceCoetzee ,
Sincerely sorry for my late reply.There might be some misundertanding
The important thing is that help you solve the issue together.
I did email you just now.may I know if there have no wifi showing after updating the Zino firmware?
VinceCoetzee
Post by VinceCoetzee » Fri Jan 04, 2019 3:36 am
Yes there “have wifi showing”. Once again, my rc and zino does not connect/pair up/talk to each other/marry up/chat/bind etc. Nor does my phone and rc connect with through anymeans including otg tethered connection.
The rc just scans for the zino and does not connect. The rc won’t connect to phone when I select wifi in app, I can not continue with “set transmitter and aircraft connection”
Haven’t you got my previous emails and messages? Am I just going have to type all that out over and over again?
