Can't pair the controller to the Drone-Solution
me_fb8b1nmgoo
Re: Can't pair the controller to the Drone
Post by me_fb8b1nmgoo » Thu Jan 10, 2019 6:00 pm
To BrettYoung
The cable fits fine but will try without the case. Thank you
To Mavros
I'll give it a go. I have been talking with Ailsa about this issue and the thinking right now is a faulty cable so they're looking into it.
Will keep everybody updated.
Andrew
BrettYoung
Contact:
Post by BrettYoung » Fri Jan 11, 2019 12:00 am
To BrettYoung
To Mavros
Andrew
My cable appeared to fit correctly in my Ipad and Iphone 6 also but it simply wasnt making connection on either.
I also ordered a Non Hubsan Cable from Amazon that just came in today but I have not tested.
Been waiting on a replacement cable from Hubsan since about December 16th and finally received a tracking number this morning.
Life truly is short and can change in a heartbeat!
Work Sucks!
me_fb8b1nmgoo
Post by me_fb8b1nmgoo » Fri Jan 11, 2019 3:26 am
Lets hope it is just the cable. That would at least be a solution.
BrettYoung please let us know if your new cable fixes your problem and I will when I get a new cable.
Tengel
Post by Tengel » Fri Jan 11, 2019 4:08 am
I never wait for the lights to go solid on zino or transmitter, I had trouble connecting before too. Since I tried my way connected every time. Turn zino and transmitter on ,open app and immediately plug in cable( usually is already plugged in transmitter)to phone. Haven't had the problem since. Good luck
me_fb8b1nmgoo
Post by me_fb8b1nmgoo » Fri Jan 11, 2019 7:53 pm
To Tengal
"I never wait for the lights to go solid on zino or transmitter, I had trouble connecting before too. Since I tried my way connected every time. Turn zino and transmitter on ,open app and immediately plug in cable( usually is already plugged in transmitter)to phone. Haven't had the problem since. Good luck"
I'll give that a go too. Thanks
VinceCoetzee
Post by VinceCoetzee » Sat Jan 12, 2019 5:22 am
To Tengal
Hi
I managed to get to the bottom of my problem and like I said will let you know the outcome...
After sending videos and speaking to loads of people the Hubsan engineers decided I have a faulty transmitter and they’re sending me a new one. The rc and drone pairing should occur like in their video. If you try loads of different weird little tricks to get it to pair then it aint right. What if you ever wish to sell it? Your buyer won’t want to mess about like that. Just a thought
me_fb8b1nmgoo
Post by me_fb8b1nmgoo » Sun Jan 13, 2019 2:35 am
Dear VinceCoetzee
Thats what I'm thinking must be the problem too and the fact that you have now got that result will serve as an example so thank you. However I have to work with Husbsan and Ailsa and follow their lead at this stage. Its a process like most things, so if the new lead doesn't work then obviously I'll bring up your example.
Again thanks for sharing.
Andrew
Jlat
Post by Jlat » Mon Jan 14, 2019 6:27 pm
Can’t connect! Was working fine 2 days ago. Was there an app update or something? Here’s my video showing the problem.
https://share.icloud.com/photos/0IgbhLk1yCgUJHiGBEsqTslIA#Home
Jlat
Post by Jlat » Mon Jan 14, 2019 8:13 pm
It’s like the Zino is not spitting out WiFi. I see other local WiFi in my house so that tells me that the TX is capable of seeing the Zino. HELP! This things not even a week old. :cry:
Djose24
Post by Djose24 » Mon Jan 14, 2019 9:13 pm
When you turn on the zino, next to the SD slot, do you know if the led is red at all times?
