Drone battery charge time?
regster
Re: Drone battery charge time?
Post by regster » Mon Jan 28, 2019 12:18 pm
Hubsan-Ailsa wrote:
Mon Jan 28, 2019 6:38 am
Hello regster,
Would you mind to test the battery by the voltmeter ?
Waiting for the further feedback
I have tested with two types of testers and I have the same result.
A cell remains out of balance
What can I do?
https://youtu.be/hRq7rcu7Gks
grandyucha
Post by grandyucha » Mon Jan 28, 2019 2:19 pm
And on my charger, the green indicator does not light up either, and when I start charging the battery, the red indicators always flash 6 times, then pause for 1 second and then again 6 times, and so endlessly. There is no controller to check how many volts are in the batteries, but after three hours of charging I insert the battery into the drone and turn on the remote with the phone, show 95% charge, turn off - turn on (restart) the drone and the remote show 100% charge. I tried to charge for 5 hours, the result did not change and the red indicators blink 6 times and 1 second pause, and again 6 times to infinity. What could it be?
fvdk
Post by fvdk » Tue Jan 29, 2019 10:16 am
Hello regster,
What can I do?
Well, the video clearly shows that the cells are still unbalanced so I would say that the charger is not working as it should. You can try to discharge the battery by flying for a while and than charge again to see if anything changes but personally I would invest in a good 3rd party balance charger which in my opinion is a good investment anyway.
I can certainly recommend the original SkyRC B6 or B6 Mini or the newer technology Turnigy or Ulrapower UP160
You can very easily make an adapter cable in 2 minutes from a standard 3S balance extension cable.
regster
Post by regster » Wed Jan 30, 2019 5:45 am
thanks I had already opted for that solution but I'm waiting for cables from amazon. Meanwhile, the loader has already arrived:
https://amzn.to/2BcOniO
fvdk
Post by fvdk » Wed Jan 30, 2019 9:51 am
Good choice!
For that charger you want the adapter cable like this (XT60 connector instead of the banana plugs):
Post by 501Pete » Wed Jan 30, 2019 12:48 pm
I've asked before, but is anyone prepared to share their Internal Resistance measurements for these packs.
I'm interested in whether I'm just unlucky on getting 3 mediocre batteries ;)
fvdk
Post by fvdk » Wed Jan 30, 2019 2:54 pm
and my other battery
I suspect these results are due to a protection circuit inside the battery as it would be a very strange coincidence that all these batteries have such a similar result.
isldoors
Post by isldoors » Wed Jan 30, 2019 5:01 pm
Get a balance charger 😀
Post by 501Pete » Wed Jan 30, 2019 5:50 pm
Thankyou.
I'm going to manually measure the IR once I can get a decent connector to support a high current load.
I feel like a dismantling of a battery pack is in order however.
I really don't understand how you can get these readings, but they are consistent!
Hopefully cell 2 is correct, and something is going wrong with the measurements for 1&3. :o
two of mine....
regster
Post by regster » Thu Jan 31, 2019 6:26 am
Hello to all the group, I made a video to build a cable (THANKS TO YOU) for charging the Zino In order to use professional magazines, WITHOUT having to change anything original! You can see it here:
https://www.youtube.com/watch?v=nQYIG_ZsXWA
