https://drive.google.com/open?id=1BW7xkpic2hJfpnakO73i0s-amf9trtMf
THIS ISSUE START TO MAKE ME CRAZY!, i update the drone all to the latest, but when i record, it's always the same doesn't matter if morning or night, it is always displayed!
CAMERA CONTINUE PROBLEM (GHOST TRAIL) ALSO WITH UPDATE
Re: CAMERA CONTINUE PROBLEM (GHOST TRAIL) ALSO WITH UPDATE
Looks like artificial light issue... Take it outside.
same happens outside
I have noticed the same issue. Most likely due to aggressive noise reduction (averaging).
Hello ClaudioLisco,
Would you mind to provide the reviwe video outside for our further checking?Thanks
https://drive.google.com/open?id=1mRn2lGAcOjjdRb9qjUCyyZRJcIP9VKCU
I have the same issue. There are lots of this black "rows" in all the videos. Some noise also when I move the camera during the flight.
The firmware is the last one.
I think the black rows you're seeing is the effect of the sunlight going through the propellers. It's happened to me depending of the angle of the sun and the camera.
I think this problem (i talk because im videomaker) happens because the camera in auto try ti catch more light so with shutter Speed go to 1/15 Speed..if i go in manual the quality Is unbeliveble ugly for ailsa you Can check My last video where this issue come also in morning outside recording..in pretty sure the problem depending from shutter Speed camera that for take more light drop to 15..for 30fps video the shutter speed must Be 50 and for the no light video must drop max to 30 shutter Speed..also Is set a high noise reduction and this dont help for nothing the recording Is Better put in post production the Denoise and not in Camera
