"Please restart the drone when using the bootster"? Say what?
- Contact:
This message appears when binging the drone to my iPhone. What is the booster? Doesn't seem to change anything, what am I missing, beside brain cells?
- ge_8efac33d06
Re: "Please restart the drone when using the bootster"? Say what?
That message appears when the transmitter(booster) connects to the Zino for the very first time. You have to restart the Zino again and go through the connection procedure. The message wont appear again and you are good to go.
- Contact:
Thanks - 'booster' is what got my attention. Thanks.
mine does it every time I fly it.
- Contact:
Have you done all the calibrations at least once? There are two menus, the top and bottom. Mine has stopped (I think.)
Hola.. Y como reiniciar el zino??
- Contact:
Apparently it saveswhat wou set. But you should still do most steps every time. Belt AND suspenders.
Yes, many calibrations. I noticed today that the notification only happened on the first flight, not on the second.thesoundsmith wrote: ↑Sat Jan 19, 2019 9:05 pmHave you done all the calibrations at least once? There are two menus, the top and bottom. Mine has stopped (I think.)
